New carburetor float
kozak_golota
For the first time rebuild 1993 3 hp Johnson carburetor. Got to the point of installing a new float from the kit. The manual says to use OMC Float Gauge p/n 324891. I don't have the gauge. Does anyone know the measurement of how high top of the float should be from the bowl gasket surface? Or should I just set it parallel to the joining surface? OMC made rocket science out of this one instead of giving measurement as others normally do.
Thanks.
flyingscott
With the carb upside down set the float to level
oldboat1
^^first use of that new manual, and now being told to ignore it! (I agree -- just eyeball it.)
gm280
I have to say, of all the carbs I've rebuilt over the years, I have yet to see one that didn't have the float adjusted anywhere but level. There is really no need for any float gauge. And there is a little lead way in float adjustments. So a little off isn't a huge issues. JMHO!
