I have two identical Merc 3cyl 60hp. When I look at the wiring in the motor they are totally different. Wires connected on one are not connected on the other. I presume that even though you have two motors they are still wired up the same. On the startboard motor just to the left of the oil pump there is a little black box with a few wires coming out of it. On the other motor this box is missing. Can anyone tell me what this box is and what it does.
The peehole pipes are also connected differently. One motor has a pipe coming out on top just under the cowling. The other comes out on the port side about halfway down. Is this normal or should I change them all to the same.
Thanks for a great forum. Good advice is hard to find here in South Africa.
