Re: New battery?
There are many arguments over what battery is necessary in a boat.
Your current battery will work.
The arguments over deep-cycle vs cranking batteries is valid. Battery choice should be made depending upon the intended use.
Cranking ONLY applications obviously need a cranking battery. HOWEVER, extended periods on fishing, drifting with power consuming accessories, i.e., depth sounders, fish finders, stereos, trolling motors, require the use of a deep-cycle battery.
Understandably, if your boat is only equipped with a single battery and you do leave accessories on for periods of time with the motor OFF, then a deep-cycle may be the best fit for your current application.
