new battery and starter barley turns over
tensix59
"i have a 1989 bay liner with 2.3 omc <br/>started it today before i took it to lake ran fin got in lake was running real good then a couple like hiccups the was fine then another hiccup or jolt then died.<br/>would not start taped on starter and turned one time ... got the boat home charged battery and turned a couple of times took battery to place where i bought it and they tested it said it was great.
what should i look at starter? and why would it shudder like that and die? looks like i may of hit something with prop its banged up but i was in deep water.
henleyhale
If the prop is banged up then you hit something that will make it die, check your engine grounds first, make sure they are well fastened and CLEAN. If that checks out, take the starter off and open it up, inspect the brushes and brush cup for damage inspect the magnets in the motor for damage. Often a starters brushes will go bad and this will cause a big drain on the battery, and not give the starter the power it needs to turn a motor over, but it will spin fine without a load If brushes are damaged or springs are burnt out replace them or get a new starter, rebuilding is cheaper and easy. Let us know how it goes
bruceb58
Try turning your engine by hand with the plugs out. If it doesn't turn easily, pull the drive and try it.
GA_Boater
Welcome aboard. 10659.
I was in deep water last week and hit something. A log was barely below the surface and I only saw it behind me after running it over No damage for me, but deep water means nothing.
Try what henley and bruce suggested first. Get the starter turning the motor over first. Check all the power and grounds, make sure all are shiny, bright. You can take a starter to an AutoZone or other major auto parts chain for testing.
On your stutter and die problem, how fresh is the gas? And change the fuel filter. The jolt could have stirred gunk up in the tank.
