new 4.3 vortec motor stalling when coming off of plane
stang32
s
[FONT=Verdana, Arial, Helvetica][FONT=Verdana, Arial, Helvetica][FONT=Verdana, Arial, Helvetica]i just installed a 2000 4.3 vortec engine with thunderbolt V ignition system. set the timing to spec 10 deg BTDC by grounding the purple wire according to the manual.
the engine runs smooth, idles nicely & gets up with ease.
the main issue is when slowing down to or near idle, the engine stalls. when restarting it, the engine cranks as if the timing is off, cr,cr,crank,cr, cr, crank, etc...but does restart.
i thought the stalling issue was bad gas, I drained it this weekend & installed fresh gas but the problem remains.. I know that bad gas will not make it crank like this so I think the issue is something else. the powerplant is a mercruiser alpha 1 gen II set up
[/FONT][/FONT][/FONT]
