New 350 Merc Long Block problems
asgrinne
Ok here is the scoop... Timing is as 8 degrees btd center 32 degress at 3000 rpm.<br />We have checked double checked the timing. Carb changed props.  <br />Boat runs starts idles runs low rpm great. <br />Tested again with 600CFm top rpm. Had the carb cleaned checked etc to make sure its good. <br />Put a Edelbrock 5000 intake manifold on. <br /> <br />3600RPM with 21 Mirage<br />4000 RPM with 19 pitch <br />Clean Bottom, bottom painted. <br />Exhaust seems fine with no restrictoons. <br />The old motor ran a 21 Mirage at 4700 RPM approx 50mph<br /><br />Fuel pressure 5.5 6lbs<br />All fuel lines are good and clean <br />Fuel filters are all good<br />The anti siphon seems to be working fine. <br />checked the linkage it is fully extending. <br /> <br />We put a 750 Holly on just to test the possibility of the the cab being to small. <br />Zero change <br /><br />Can anybody think of anything else we can check. <br />It just never gets going. I really think we should be able to get the rpms higher? With more power behind it. <br />The guy we got the motor from says its at least 310 horse. We are simply baffeled at any other things that could be hosing it up. <br />Thanks very much in advance.
jmccall001
Re: New 350 Merc Long Block problems
if you are playing with the prop try a 17 pitch, that should bring your rpms up to abt 4400. close to specs for the 5.7L
rbezdon
Sure you dont have a dirty bottom or an exhaust restriction. See many of the posts and solutions for FreebyTony, especially the suggestions from Don S on the exhaust restrictions. (Check the flappers!!)
asgrinne
If you are one tooth off on distributor would the timing appear correct and read "right" would that cause the no top end problem
Chris1956
anita, If you are off a tooth, the timing would be off as well, and you would turn the distributor body to adjust it.<br /><br />Are all the plugs firing? I hate to say it, but do you have good compression in all cylinders? It just sounds like a tired engine, rather than a new one.
whywhyzed
Banned
a thousand pounds of water under the floor boards?<br /><br />what cam went in the engine? cam out a tooth?<br /><br />compression test it just for laffs..
asgrinne
engine has a Marine melling performance cam and lifters your cam spec is 220@50 with a 110 lobe separation <br /><br />Not real sure what this means. But does that help? <br />We are going to check the resistor angle now.<br />Boat is dry
Borre16610
Ive had the same problem. The valves was too tight..I friends new long block had the same. Both GM 350s<br /><br />Borre
rbezdon
that means .220 inches of lift at 50 thousndths clearance. 110 degrees of cam rotation between the intake and exhaust lobes. Sounds like a very stock cam. Search for a posting by me on cam specs, ralph posted the marine, car and truck specs for roller and flat lifters. You can compare. Cam lift is then multiplied by the rocker arm ratio to get valve lift. Stock rockers are 1.5 to 1 so your getting .34 lift. Low for marine I think but check the posting to make sure.
Fishermark
I would definately do a compression check before doing much else. <br /><br />
I don't know if you have posted something else in another post, but if this is a used engine you have installed, or even a "rebuilt" engine, it could simply be low compression. Either from being old and worn out, (like me with every passing day :D ), or from improper break in.
