vesselgreenhead
- Jul 10, 2001
- 39
I just bought a new 150 Mercury Salt Water Carb. I'm in the breaking in period and have about 3 hours on it. After running it as recomended by manuel with different speeds, I decided to touch the water coming out of the t-tale after 30 minutes or so and it like to burn my hand. It's so hot that I can't leave my hand in it for longer than a couple of seconds. IS THIS NORMAL? The alarm for over heating has never gone off. I was also reading on this board that if the prop is not pitched right, this could over heat the engine also. I brought it up to full throtle two times and got it to 5100 rpm's. I am also told that running the double oil during the break in period will not achieve an accurate rpm range and that it could be more accurate when I begin to run the 50:1 ratio. Is this true because it don't idle very good, it's very rough and smokey. I have a mirage plus prop pitched at 19", should I bring it back and exchange for a 17" or will my rpm's go up after the break in period. This prop also has 3 plugs on it, should these be removed for higher rpm's?? HELP PLEASE!
