jeffb928
- Jun 29, 2007
- 22
Hello need some help about new motor trouble, new motor is leaking gas from under front of shroud out of a small white plastic fitting. I opened the shroud when i saw it leaking because i thought maybe a fuel hose came loose or broke ,and that this fitting was a drain of some kind but it has some kind of a hose on it . any ideas on why gas would leak here only when idle or slow speed not when moving fast? also runs fine ! would like to know if it is something that i could fix??? Thanks jeffb
