Never seen this before
Pa mountain man
Ok, I have a 16' trailer, with new harness,lights, and fresh grounds, my truck(01 Tundra) has a new taillight converter/harness, and fresh grounds, I get power at the rear of the truck at the harness, but none at the rear of the trailer. When I pulled a u-haul last year(8 or 10') the lights were very dim, I'm thinking the system needs a power module to boost the amperage up to 4 to push some voltage to the rear of the trailer, what do you all think?:confused:
Gary H NC
Re: Never seen this before
Nope, Still have a wiring problem. A 16 footer should not need anything to boost power to the trailer lights.
Have you tested the voltage output at the vehicle connector?
Also try running a separate ground wire to the rear lights if you are using the trailer frame as the common ground.
jusfloatin
My bet is a bad or several bad ground connections.
mikeroche
i agree my friend is a wizz with wires and he says always check the ground first
