I have a 1984 60 hp evinrude with a johnson command center remote and i am having a problem with the neutral safety switch. How do i bypass it to check if it is bad
^^If you have located the switch, test for continuity between the two posts when the plunger is pushed and released. If working, adjust mechanical operation as needed.
