Neutral Safety Switch problems
I think my signature includes this, but, just in case: I have a 2003 Odyssey Lextra with a Mercruiser 350 Mag MPI I/O Alpha one outdrive.<br /><br />For a good time period, my motor has been difficult to start, Especially when Cold. I'd have to move the Shifter back and forth some to find that "Just right" position for the starter to kick in. I went out to start my motor this evening, and run some fresh water through it, let the motor run some, before draining the water out of the block. Well, I just was unable to find that "Just right" position. I'd turn on the key and get the Starter click, but the motor would not turn over. All fluid levels checked OK. <br />I finally was able to figure out how to remove the cover over the shifter, but didn't see any type of adjustment screw to set "the Neutral Safety Switch?" In the past, sometimes I'd have to shift the gear forwards/backwards a time or two, then push in the Neutral button push the throttle forward to idle it up, and it would start. No go this time. <br />Any suggestions on getting this Adjustment right? When I removed the cover they had some linkage, with a Ball bearing that would pop in and out as you moved the shifter forwards backwards.
