neutral is not at (12) top dead center
LukeLee
Boat: 2004 four winns funship 194
Motor 5.0
Neutral is not at 12 o'clock/top dead center. I was on the water messed with it a little really tight space and hard to get to but found out that neutral was at 2 o'clock and forward and reverse still work. Did some research and don't know what to do?? Help thank you
welcome aboard
5.0 what?
are you talking the binnacle? which brand of outdrive?
your cable could need adjustment or replacing. follow the manual for shift cable adjustment
