neptune mighty mite parts
craveman85
anyone know where i can get a manual and or parts for a neptune mighty might motor? i just got one from a friend and wish to restore it.
steelespike
Re: neptune mighty mite parts
Try on the forum or free webvertize at www.aomci.org
Those a cute little motors they appear much older than they are.
They all look pretty much the same right up to the early 80s.If you have a model number I may be able to date it for you.
craveman85
mainly i need a pic of the wiring for the ignition under the flywheel if anyone can get me one. not sure of the model number since it needs a good cleaning at the moment. it may be older than the actual mighty mite ones.
F_R
Honorary Supreme Mariner
Hope this helps.
Tom @ Buzzard Bluff
Parts source has been in front of you of all the time. See thread entitled "Picked up this little gem" immediately below.
craveman85
its a 1938 2hp model number 2a38. appears to be complete except for the exhaust pipe. has good compression. i just derusted the tank last night with works toilet bowl cleaner just make sure you remove aluminum parts if you do it that way.
craveman85
anyone have a picture of the wiring hooked up not just loose parts?
craveman85
i soaked the tank in works toiletbowl cleaner and all the rust pored right out.
craveman85
nobody has a pic? all my wires were old and broken i need help!!!.
F_R
There aren't that many wires. The coil primary wire goes to the points. The condenser wire goes the same place. You can see them in the picture I posted, but you have to look close.
craveman85
ive got 2 red wires and a negative coming off my coil as well as the spark plug wire. is there an aftermarket coil and condenser i can use to replace these old parts?
