Needs to know the order of fuses
Snowbird 1111
Hello I have a 2015 Mercury 40 horsepower tiller SS ,my one fuse blew out and I took off all the fuses and forgot the order so if you can fill in the blanks, it will be greatly appreciated.oh and by the way the left side is the injectors side and the right side fuse box is where the starter is located.
Alumarine
Welcome, you can get a user manual which should show the fuse info from here.
Snowbird 1111
Yeah I tried that, I was able to get the ones on the starter side through Google, now for the fuel injector side.
Snowbird 1111
I got the order of fuses and the 15 amp fuse blew out on the starter side so I found the culprit it's a cable diode adapter.
Snowbird 1111
