Needle&Seat leaking
mikes 86
i have 86 125x4 two carbs, did carb clean last week because of hesitation at wot, also hard to start after sitting for a while on the water, cleaning did not help problem, took carbs apart today checked needel & seat top carb leaking just a little Big question i have pressed in seats needle doesnot have small holding clip can seat be replaced or not, if can where can i get them or do i just replace needle. THANKS
jerryjerry05
Re: Needle&Seat leaking
Do an inspection of the needle and seat.Go to this thread and see pic http://forums.iboats.com/showthread.php?t=506790
It shows a drawing. Compare this.Look at the seat in the bowl.Sometimes they de-laminate and won't seat right.
Seats can be removed but I wouldn't want to try it.I think FrankA does.
I sent you a`PM.
mikes 86
Thank you jerryjerry05 for your response and your PM, i will let you know what i figure out.
