Needle Bearing Grease?
petiboy
I am changing my water pump on my 96' Evinrude 115 and the manual says to use needle bearing grease on the cam key on the impeller, can I use the standard triple gaurd grease or the moly grease that came with the water pump kit. Seams like 3 different greases to do one job is overkill.<br /><br />Thanks,
Joe Reeves
Re: Needle Bearing Grease?
Use any grease you might have there, makes no difference.
