tristanlee85
- May 15, 2011
- 32
Last fall, I had a bit of a mishap with ramping a tree in the middle of the river which dinged up the prop and skeg. I've since had the prop repaired, but the skeg still needs works. I ended up getting a Panther skeg guard, but the additional thickness and lack of torque wedge made a noticeable decrease in performance. The boat always wanted to pull one way and required so much strength over 60mph it was almost impossible to hold on to (no hydraulic steering).
I would like to get a replacement skeg that I can have welded on. Since there is a lot of meat left to this, I would assume the right template can be cut out to weld on to the factory skeg. In my search for replacements, I have found a number of different ones (http://www.firstchoicemarine.com/c-392-skeg-products.aspx#Filter=[ManufacturerID=236*Sort=0*ava=0]) but I am not sure which one is best for my lower unit.
Is welding on to the existing the way to go, or should it be welded directly to the housing?
https://drive.google.com/file/d/0B6IcI8X55ouebGlubUFLWmNWQUU/edit?usp=sharing
https://drive.google.com/file/d/0B6IcI8X55oueQjBQUEdUZ0RfMGs/edit?usp=sharing
https://drive.google.com/file/d/0B6IcI8X55oueZGtrUTZ4Z09qZmc/edit?usp=sharing
