Needing advice on a new prop
James Perkins
I have a 1984 Alumacraft 16'0" in length and i am running a 1985 mariner 50 HP motor. I have spun the prop and i can not find the pitch on it anywhere. What prop would would you suggest i put on it?
Ayuh,.... Welcome Aboard,.... Have ya taken the prop off the motor,..??
There should be a part number/ pitch on it somewhere, possibly under the prop nut,....
Sea Rider
As you haven't tached that 50 with current spun prop, will need a prop to do so, then go for a prop maximization as currently loaded to take the most out of that 50 HP. Any prop you choose will be your starter prop...
Happy Boating
James Perkins
I have not pulled it yet. I will pull it soon and see what's there. Thanks I'll be getting back with you on that.
