need year and any info on this evirude ty
John.F
I have this old evinrude here my dad gave to me,<br />the model# is 115983E the serial# is C59291.<br /> He says I Should get it running. lol<br />anyway, it's not seized up but has been sitting for 9 months, and I can't see the shift linkage for forward or reverse ? is it electric shifting?<br />I cannot get it out of gear.<br />any and all info would be great. thanks.
Droll
Re: need year and any info on this evirude ty
How does this one look :<br /><br />1969 Evinrude V4 115Hp Wot rpm 5000 Bore 3.44" Stroke 2.59"<br />Ignitin type III = Capacitor discharger (CD) with sensor .<br />2 double barrel carburetors .<br />It got Type V Electricc shift with 2 solenoids .<br />
The forward gear is a "default" for the gear case , it will go into neutral when starting( no current down to lower unit = forward gear )<br />If you want more info ,do a search on the forum (type c , el hydraulic shift )
Joe Reeves
Gilligan.... Your 1969 115hp Evinrude has what is called a "Hydro Electric Shift" lower unit assy. The following may be of interest to you.<br /><br />(Hydro Electric Shift)<br />(J. Reeves)<br /><br />The shifting setup of the lower unit is what's called a "Hydro Electric Shift", which is quite complex consisting of voltage being applied to solenoids in the lower unit which in turn change oil passages via a oil pump that supplies various pressure on a spring loaded shifter dog. The wires leading to the lower unit (at the powerhead) are "Green" and "Blue". The engine must be running or cranking over in order to shift out of forward gear.<br /> <br />You CAN NOT use HI VIS lube in that lower unit. You MUST USE what OMC calls "Preminum Blend" lube, commonly called "Type C". (A thinner lube) <br /><br />In neutral, you need 12v to the "Green" wire. <br />In reverse, you need 12v to both wires, the "Green" one and the "Blue" one. <br />In forward, there should be no voltage to either wire. (The spring loaded shifter dog forces the unit into forward gear) <br /><br />To check the lower unit for proper shifting to make sure you have no trouble there, remove the spark plugs to avoid problems and to allow a higher cranking speed. <br /><br />This next step eliminates the actual shift switch in case problems may exist there.... Disconnect the blue & green wires at the knife connectors (the rubber insulated boots) leading to the lower unit at the powerhead, then using jumpers, take voltage direct from the starter solenoid to apply voltage to the "Green" wire for neutral, then both wires 'Green" & "Blue" for reverse (Remember the engine must be cranking over in order to shift).<br /> <br />With no voltage applied, the unit should be in forward. No need for a ground jumper... the lower unit's already grounded. You may crank the engine with the key switch or by energizing the starter solenoid with a jumper wire.
BillP
I had a new omc 115 in 69 and had lots of trouble with shifting and starting. It did all types of weird things...jump into gear when at idle, suddenly not be able to start warm or cold and stop running at high speed as if the ignition was turned off. When it quit we jumped wires on a terminal bar on the block to get it running(if memory serves me right). <br /><br />OMC mechanics said there were problems because of the new electrics. OMC kept replacing parts under warranty and still never got it running very long before the problems came back. That experience has always made me leary of that year 115. <br /><br />Lucky for me some dirtbag stole the motor off the boat while it was at the dealer for service and I got out of it ok. :D
