Re: Need Wiring Diagram for '95 Johnson Faststrike 150 GLEOM
Use the '89 35 amp drawing. It will be close enough for what you are doing.
You will not get amps, I am afraid, volts yes, amps no. Oh it can be done...but urfff...big big wires spliced in to the stator output,
running to the helm and back. If you do tackle an ammeter, you better do it right....
Fuel is from the tank sender, no engine wiring for that.
Tach is the grey wire that exists in the wiring harness that runs to the helm and attaches to the tach there.
Purple is switched +12 VOLTS.
Red/purple is always hot (not switched.) Goes to the key.
Trim is off the trim sender located up under the tilt/trim mechanism. Looks like 2 black wires, but it is just a pot.
Black is ground at the key, black/yellow (stay away from) is engine kill. It is NOT ground.
