Engine is 1993 Volvo Penta 570 MS4, Prestolite Electronic Distributor w/Mech. Advance
Nothing is wrong, engines run, I want to time them and don't understand the service man terms of initial timing and final timing (at 3000 RPM)
1. Is initial timing at idle the "set to" value?
2. Is final timing what should be observed at 3000 RPM (assuming advance, distributor, timing gear are working well)?
3. If observed final is wrong, are there other causes?
3. Since this is a mechanical advance, does it matter if timing is done under load or at the pier?
4. Can a substantial error in the distributor sensor gap affect the timing (like dwell)?
Thanks in advance, this a great forum..
