reelfishin
- Mar 19, 2007
- 3,050
I have a trailer that has two 3500lb axles and springs and was built to fit a 21' boat tops It needs to be made longer to accomedate a 26' boat, I looked another trailer like it that had a larger boat, it looks like the only difference is the a longer tongue, and they slid the axles forward a set of bolt holes.
The 26' boat is about 5000 or more pounds, but the last owner had it on a single axle trailer with the bow extending over the tow vehicle when in tow.
I like to have some distance between me and the boat, especially for launching.
If I make a new tongue out of 3 x4" tubing, the tongue will be allmost 12' long overall, it's 9' now. I think so long as I use a heavy enough guage tubing I should be fine?
The intitial goal is to simply get this boat home, if I need to find a larger trailer later, then so be it, but for now, this is what I have and a new tongue is a cheap remedy. I can by a length of tubing for under $50 and weld up a new tongue in no time. The main frame is as long as the new trailers they sell down at the marina that are under 26 and 28' boats and mine is also wider with heavier axles.
Also, should I step up to a 15" tire from the existing 14" to gain some capacity? It would add some unwanted height though.
I could also add the the main frame, but since this is a deep V style trailer with v shaped crossmembers, make them up would be a hassle.
I've had as long as a 24' boat on this trailer as it sits, but it was a bit short, and this 26' is a lot more boat than that one was.
