Need to ID my Johnson 70 HP outboard
Terrormuffin
Hello,
I recently bought a boat with a (presumably) late 1980's or early 1990's Johnson 70 HP outboard. The outboard has been repainted at least once in its lifetime, and as a result of that there are no ID tags to find anywhere.
On the "freeze cap" on the engine block, the number G4142793 is stamped into a metal disc. I've found that this number is a serial number which can be used to identify the outboard's model year and other features, but I can't find anywhere to look up this information.
The engine runs and holds together at the moment, but there are quite a few parts that look worse for wear and need replacing. I also need to get the correct service manual for it for ongoing service, so if someone could point me to a website where I can look up the outboard or look it up for me, I would be most thankful.
Cheers,
Christer
jakedaawg
Serial # is only good for the factory to look up.
post some pics inside and out and we can give you a close enough range for parts and manuals
boobie
Call BPR customer service with that #. They may be able to help you.
Honorary Supreme Mariner
No, not at all.----Most of those discs now only have the serial number !!-----In olden days they also had the model on the disc.
Terrormuffin
Hi again,
I'm not a one and done poster, it's just rather busy at the moment. :)
The boat was launched the other day, so I haven't been able to take pictures yet, sorry.
I've seen many posts where people have posted their serial number and gotten a reply with the model number, so I was hoping that would still be a possibility. I could give BRP a call, however, I'm in Norway and I'm not quite sure how that would work out.
With regards to the silver disc, it only has the serial number on it, unfortunately. Had the model number been on there as well, this thread wouldn't be here.
I'll head down to the boat tomorrow to snap some pictures. I did find pictures on Google Images that look like my engine; here's one:
https://i.ebayimg.com/images/g/zMQAAOSwdGFY3Unf/s-l300.jpg
My outboard has electric start, tilt assist (no electric trim) and a black gear housing. Presumably it was replaced at some point in its life. The gear housing doesn't look to be repainted, but the rest of the covers and cowling have obvious telltales of bad paintjobs.
From the decals (assuming the cowling and/or decals are original), I think it falls between 1992 and 1994.From what I've seen, the decals on the 88-91 models have dark grey HP numbers, and the 1995 onwards have completely different decals and cowling designs (but I have been wrong before).
Terrormuffin
I have contacted Evinrude/BRP through Facebook and given them the serial number, and they are looking into it. Hopefully they'll be able to give me the model number and year so that I can get a service manual and some spare parts that fit. :)
fireman57
I apologize for making that assumption. Hope they can give you an answer.
Rustywrench
I believe you will find that is a 1992 model. J70TLEN. Google is not always a good indicator, but it matches what you show. You know it's after 1991 because it has the newer TRAC midsection & trim system. Hope that helps narrow it down. Originally BRP had quit looking up anything 1995 & older. That was many years ago. Maybe they have decided to be more helpful now?
Terrormuffin
It seems the 1992-1994 models were pretty much identical from my limited knowledge of Johnsons, but I'd like to pinpoint the exact model and year just to make sure I get parts that actually fit.
Still waiting for BRP to come back to me with more information (or no information).
