Need to disconnect VRO alarm but can't find the wires!
beachcrafts
The VRO system has been removed except for the alarm. I can't find the proper wires even looking through the manual and looking at the engine. This is a 1984 115 Johnson. I have photos of both sides. Please help. This goes off everytime we get up to 3300 rmp. Thanks
CadillacsCowgirl
Re: Need to disconnect VRO alarm but can't find the wires!
Coming out of the top of the VRO side if your fuel pump there is a 4 wire harness, unplug that and it should cure the alarm...
w2much
Do not just unplug the wires . Do not run the engine without premix while you are testing your alarm. Be careful here.You do not want to cure the alarm and not the problem.
