Need Tach Wiring
bhalsdorf
Anyone know how I can wire up a Tach to a 1958 Johnson 35hp ? Also what setting on the tach should I use ?
mellowyellow
Re: Need Tach Wiring
welcome aboard :) <br />if you haven't already purchased a tach, I reccomend<br />"Tiny Tach", just hook to 1 plug wire and ground.<br />cheap ($35?) and easy, and works on all OB's.<br />think they sell them here???<br />good luck,<br />M.Y.
bhalsdorf
Unfortunitely I already have 2 tachs here. Almost done restoring my 1958 Tru Ski and almost out of money for extras so was hoping I could use one of these.
bhalsdorf
The one I really want to use is an old Airguide. It has 2 wires coming out of it and a 5 position switch numbered 1,2,3,4,5 and the 2 wires are Yellow and Black.<br />The other I have no idea what it is but it had 3 lugs marked Ignition, Send, Ground and has a switch marked 2P4C, 3P4C, 4P2C, 5P, 6P (P=pulse,C=Cylinder)
rickdb1boat
Bill<br />Won't work on your Motor. Get the Tiny Tach.
bhalsdorf
Well I can't seem to find that "Tini Tach" here. Oh well, will keep looking.
jlyar
Anyone know where to buy the TINY TACH's that seem to be recommended here? I can't find any reference to a dealer that sells them.<br /><br />Thanks in adavance.<br /><br />John
bhalsdorf
I found out my Airguide Tach will work on my motor. Also got the wiring and setting. Seems Minn-Kota bought out Airguide in 1993 and they still have alot of the old information on file. They were very helpful.
rickdb1boat
Great Bill, I didn't know if your Model had an Alternator. Assumed it didn't have an Alternator system. Glad it worked out....
Steve135
mellowyellow I checked out the web site that someone else posted for tiny tach. I can't find one for a 3 cylinder outboard?<br />steve
bhalsdorf
Rick,<br />No alternator...has a generator....but these old tachs have a built in system so you can hook right up to the wire coming off the magneto to the switch and the other to ground.
