So I recently bought a 95 reinell 2030brxl with what I thought to be a 350 Chevy. The boat is 20' and has a wake tower. I noticed the engine seemed a little tired and after higher rpm runs when I would come to a idle it would smoke for awhile, blue ish oil smoke ( figured bad guide seals), well one day on the river I opened it up and held full throttle for prob 45 seconds or so and it was raving to roughly 5800 rpms and we got to about 45mph, then after that later that day I noticed it not wanting to idle well and had a tick coming from the engine, at this time I had good oil pressure. Long stores short took it out to the lake for the 4th and had a boat full of people and gear and towed a tube, well boat seemed wayyyy under power, wouldn't get up on plane without everyone moving to the front and even then was reluctant to do so, eventually the motor started rattling and seized. So engine was pulled out, torn down to find blownHead gaskets both sides. So far that's all I see, main bearings look good, rod bearing and Pistons look good, there was about 2 gallons of water in the engine so I believe it hydro locked and not seized, now, I ran casting numbers and turns out it's a 70-72 sbc 400. So I was planning on buying a 99 vortec 350 from a friend and I have a carved manifold for it. It had 150k on it from a wrecked suburban but ran great before pulled. I would like more power in this boat but don't want to spend a fortune, so, do you think I should retrofit this vortec in the boat or do a quick rebuild on the 400? I have a friend who owns a engine shop so I know I could get the 400 going for fairly cheap but the vortec is only $350, and it would need to run a electric fuel pump so there's another $70 ish, and I would probably have to buy a new flywheel as the vortecs have a different crank bolt pattern. Does anyone have experience with These motors? I know the 400 is supposed to be a torque motor which is good but the vortec is rated close to 300hp from factory.
