need some info on a 40 hp 1963 bigtwin
toddheath
Model # 40302 Where do i find a generator pulley and belt? and does anyone have a diagram of how to wire the ignition?
Thank You
JB
Re: need some info on a 40 hp 1963 bigtwin
Howdy, Todd.
Welcome to iboats. :)
You can probably get a generator and belt from an outboard dismantler, like www.tcoutboard.com, Todd.
Please don't ask for copyright violations. You need a manual anyway and it is in there.
Good luck. :)
tx1961whaler
Howdy, Todd.
Good luck. :)
Manuals at www.outboardbooks.com
Can also find them (sometimes) on ebay.
The wiring is pretty complicated on the generator models; you'll also need the regulator box and wire harness. Unless you can find all of this on a parts motor, it will cost you more than the motor is worth. It's easier to just charge up the battery with a battery charger before you go. It'll last a few days of use before you'll ever need a recharge, unless you're running alot of lights off of it.
F_R
Thank You
Sounds like you are asking about a pulley, not a whole generator.
305411 generator pulley
305415 top flange for generator pulley
307577 generator belt.
That stuff is all available from any Evinrude dealer.
