Need some help....
Newbie@boats
This is on my 2000 Yamaha 50HP 4-stroke
Last time I had the boat out it ran excellent besides one hiccup(misfire/running rough for about a minute)
This time took it out and it was hard to start but ran like a clock above 1500 RPM but at low idle it'd be rough and die.
Realized the gas tank wasn't venting air and released it and boat seemed to be better but problem still presented itself.
Got home and realized the choke when you push the key in wasn't doing anything no clicks or anything disconnected it and applied 12V and it clicks so I don't think it's a bad solenoid. Where should I go from here? Would that cause an issue even if the engine is warm from going to fishing spot to fishing spot?
