Need some help with prop size please...
budbecks
Ok. I'll do my best with stats. But cant give all for reasons stated below.<br /><br />---------------------------<br />#1. Yamaha 2 stroke 55hp electric start longshaft.<br />#2. 10"x12" (wrong prop, told by mechanic who serviced engine)<br />#3. unknown (brought a rev counter but doesn't work)<br />#4. GRP Fibre glass. Cathedral hull (tri-hull)<br />#5. No jackplate Used.<br />#6. No tabs or foils.<br />#7. Need mainly for fast as possible getting around. We use the boat for fishing and we just dart from place to place.<br />-----------------------------<br /><br />Ok, The boat can be viewed here<br /> http://dvddealsuk.com/boat <br /><br />It is a wilson flyer, made in the UK. Dont know what year or what not. The engine is a 1984/85 yamaha 55hp with electric start. I haven't had a rev counter but brought one of ebay which has worked once and now just goes off the scale every time. The pole selector is set to 6 pole which was advised by someone. The prop currently on there was a mercury prop and did not push the boat. It used to get to about 1/2 throttle and then the revs just died so we never pushed it any further than 1/2 way.<br /><br />As you will see on the web page i have brought 3 props off ebay of different sorts to try out but i desperatly need some help getting the right prop.<br /><br />More info. Usually have 3-5 people on board. 2x 25 ltr tanks. some fishing gear (not much mind) and a few tinnies :) <br /><br />Any help at all would be a very big help for me and i might start using less fuel !!<br /><br />Many thank in advance for any advise.<br /><br />John
