jbjennings
- Jul 18, 2007
- 3,903
Motor is idling good, although it was fouling plugs yesterday and having intermittent spark on one cylinder yesterday when running low speed for any length of time. It would be o.k. for a minute or so after a full throttle run and start fouling a plug again. When applying throttle for full speed, I have to give it full throttle and let speed build up, then back off a little until it hits kind of a "sweet spot", and it will sound smoother and run faster than it will with absolute full throttle. It sounds as if it's "pinging" if I apply full throttle and will seem to bog a little. I have set the timing properly, and tried both retarding the timing and advancing with no positive results. I have recleaned the carbs with no effect either. It takes low speed idle adjustment well on both carbs., and I've rodded out the high speed jets as well. I even tried running it with the cowl off to see if that'd help---it doesn't. It also has a brand new NOS fuel pump. Pumping the primer bulb has no effect.
I'm really at the end of my skill on this motor. I've never had one I couldn't get just right eventually. It has 146psi on one cylinder and 150 on the other (new rings and good pistons), so compression seems good. The old fiberglass boat I am pretty confident has no water inside the hull. It also has a brand new stainless prop of the proper pitch.
Any suggestions woud be greatly appreciated. I put 2 brand new plugs QL77JC4 in it today and didn't have a bad fouling problem. I also have a new thermostat in it as far as I know but don't think it's reaching full operating temp. I suspect that may be the problem with the plug fouling but could it also affect WOT running that badly??? I've also done the choke fix so it's not closing the choke at low speed.
Thanks,
JBJennings
Thanks,
JBJennings
