hi there my boat is a 1979 mercruiser with a alpha one outdrive, I change my water pump impeller and base on my lower unit and when I drain the oil out of the lower unit I see a lot of metal particles on the oil, I change the oil put everything back and run the engine, drain the oil again out of the lower unit and again was full of little metal particles what this means? what can I do thanks.
