Need Replacement tilt/trim 1978 Johnson 115
Joeschroeder
Hello, I'm having trouble finding a replacement tilt/trim hydraulic pump for my 78 Johnson 115. I found one on eBay but it turned out to be too small. The prestolite pump I have has about a 4" circumference. It was not holding the engine up (slowly let down) so after changing the fluid and relief valve oring did not fix it I took it apart. I did not see anything obviously wrong or worn so I put it back together and now it is worse. Any great ideas or aftermarket fixes that will fit this engine would be appreciated.
