Need Replacement Aftermarket Tilt Motor/Pump for 82 Mariner 50hp
jpietraszewski
I need to replace my aftermarket Tilt Motor/Pump for my 82ish Mariner 50hp. The old pump is shot and I would like to replace it with a new replacement Tilt/Motor/Pump but have no idea what size or type pump I can use to in place of the old one? I have attached a pic and appreciate any suggestions.
Chris1956
Re: Need Replacement Aftermarket Tilt Motor/Pump for 82 Mariner 50hp
There used to be an aftermarket motor and upper reservoir assembly. You would reuse the bottom of the pump/reservoir. However, there were two types that looked identical. On one of them the armature was too short to engage the pump. Do a search on ARCO replacements PTT motors and see what you find. I would recommend you match them up due to the armature difference.
