Ok just got my force 90 replaced with a Mercury 115 (1991) and used the controls that were on the force motor. My problem is trying to get the throttle and shift cables set. Not sure what to look for when starting this process. Messed around with the throttle a little bit and tried to start it but it appears there is more to that setup than just running the gas and can't get it set right to even get it running decent, let alone idle. Haven't even tried messing with the shift cable much yet. Any help here would be greatly appreciated. Would like to get the boat out a little on Monday if I can get it to that point. Thank you.
