Hi I am trying to raise the rpms on this boat with a 1990 70hp evunrude. The boat is a 20 ft flat bottom with a slight V at the nose. I know the motor is small! It had a 4 blade composite prop that was dammaged and thrown away before I saw the size it was. The boat was able to do 21 MPH with two adults onoard. It now has a 13 X 19 3 blade and the rpms are only 3200 at WOT I have both a 13 1/4 x 17 and a 12 1/4 x 15 to try. I am a bit confused on this end of the motor I know alot more about the powerhead! The small gearcase large gearcase thing confueses me also.<br />The 12 1/4 x 15 is off a 1980 60 hp which is a small gear case but fits the 1990 70 hp large gear case ??? I think if the formular is correct that I would gain 250 to 400 rpms per pitch change I need a 14 X 11 to be at 5000 rpms.<br />steve
