Folks I need some suggestions as to the proper replacement prop for my fishing boat. I believe I am currently overproped as the hole shot is sluggish and the tach reads 4800 max @ WOT. The top speed is fine, what I want is to be able to get on plane more quickly. Last weekend I was running 29 MPH with me, gear & a full tank of fuel. I added two additional anglers and a heavy cooler and could not break 13 MPH.<br /><br />I suspect that the dealer I purchased the new baot/motor/trailor package from this spring did not make much of an effort to get me propped correctly.<br /><br />Here are the particulars
<br /><br />The boat is 17 ½ aluminum North River revenge which is rated for a maximum of 60 HP.<br /> http://www.northriverboats.com/models/all/specs.php?productid=5 <br /><br />Honda 50 HP tiller 4-stroke currently with an aluminum C3x11.1x14 factory prop, Hondas recommended RPM range is 5500/6000 RPM so Im running about 1000 RPM low. The motor has ~20 hours on it.<br /><br />Loaded weight is 1400/1500 lbs empty (not including me & a passenger or two).<br /><br />Im running the boat at elevations of 4500 to 6000<br /><br />Thanks in advance, John
