alamosaddles
- Jun 9, 2008
- 104
Ok, boat details..
Total weight of boat, rider, fuel and gear, on the water 1650 Now corrected to 1722 to adjust for the heavier 150 hp
Boat type Sea boss 19ft bay
Motor Johnson 2003 150hp
Manufacturer WOT RPM is to be 5500+/-
Motor runs perfect, no issues. Has less than 30 hours. I purchased this new in 2004.
Propellers tested
QL 3 blade aluminum, 14.8 x 17p
Piranha 3 blade composite 14 x 19p
Piranha 3 blade composite 14 x 21p
The aluminum blade prop I cannot return, so I am stuck with it.
The Piranha prop, I can return and exchange blades, so I am looking for the guidance of boating professionals in picking the better two sets of blades to exchange for. The boat is used primarily for watersports, pulling tubes etc., to include flying tubes like the Manta Ray.
As you can see from the tests I did today, I could not hit the Manufacturer WOT RPM number with any of the props. Suggestions on what to exchange for with the Piranha? Thanks so much.
Propellers tested
