Need opinions on the Evinrude 300hp V8
dorkus69
I am considering the pruchase of a 25' Grady White that is outfitted with a 1993 Evinrude 300hp V8. I have owned several outboards in the past, but nothing like a V8 outboard. <br /><br />Can someone give me an idea if this outboard is a good unit to own, or maybe some insight as to what problems I can expect owning this outboard.
Dhadley
Re: Need opinions on the Evinrude 300hp V8
I have owned several and love them. Make sure it's set up correctly and will turn plenty of RPM. Take note where the rev limiter is and get within 300 to 500 RPM with your AVERAGE load. Make sure it's mounted high enough. The 20" model is actually 23" long and the 25" model is 28". A hint -- if you set it up to turn only 5300 to 5500 RPM you will hate it and it will not last.<br /><br />One thing to remember -- they live on fuel pressure. 3/8" fuel line and no 90 degree fittings. The dealer can run fuel pressure and vac***e tests. <br /><br />87 octane (fresh) good oil and champion plugs.<br /><br />Good luck!
dorkus69
Thanks Dhadley,<br /><br />I spoke with a man today who owns a outboard parts business and he stated that he would not recommend the purchase as the parts will be more and more difficult to find. I am not completely detered though. The trick will be for me to find a mechanic who is familiar with these units and has the technical knowledge such as the fuel pressure and rpm settings you detailed.<br /><br />I am curious to discover why these units never evolved. In 2001, I do not beleive anyone makes a V8 outboard anymore.<br /><br />Thanks again,
Dhadley
OMC continued to produce the V8 but for overseas sales only. It was so popular overseas that I would think that Bombardier will continue to produce them. All OMC dealers have the specs (in the service manual) as do independents who work on OMC engines. <br /><br />Good luck!
cobia5
Dhadley, I just purchased a 1988 v8 Evinrude. Please give details of your previous statements.<br /><br />Dhadley-"I have owned several and love them. Make sure it's set up correctly and will turn plenty of RPM. Take note where the rev limiter is and get within 300 to 500 RPM with your AVERAGE load.<br />A hint -- if you set it up to turn only 5300 to 5500 RPM you will hate it and it will not last."<br /><br />Question-What is the suggested maximum RPM?<br />What do you mean by "get within 300 to 500 RPM with your average load", what should the boat speed be given the RPM range? How do I calibrate this adjustment?<br /><br />Dhadley-"One thing to remember -- they live on fuel pressure. 3/8" fuel line and no 90 degree fittings. The dealer can run fuel pressure and vac***e tests." <br /><br />Question-Is an electric fuel pump recomended for this motor to aleviate the posibility of low fuel pressure?<br /><br />Dhadley-"87 octane (fresh) good oil and champion plugs."<br /><br />Question-Since this is a high RPM engine, would 89 or 92 octane be preferred to prevent premature detonation in the cylinders?<br /><br />Please let me know.<br />Thanks
D
DJ
Guest
Cobia,<br /><br />I'll throw in my $.02 worth.<br /><br />1. There is nothing really exotic about the <br />V-8. It was based on the V-4 and V-6 engines that preceeded it.<br /><br />2. I would not recommend an electric fuel pump in a boat. If you break a line, the fuel will be pumped into the boat. The standard fuel pumps are more than adequate, just make sure they are producing what they are supposed to and the fuel system is free of restrictions.<br /><br />3. RPM. "Average load" means what you usually have your boat loaded with: average number of people, average fuel load, average gear. <br />You cannot set up a marine engine with a speedomter, a tach. is absolutly essential. What DHadley was telling you is that the engine should operate at 300-500 rpm. of where the rev limiter is set. The dealer can tell you this. Essentially, this engine does not like to lug, it likes to rev.<br /><br />4. 87 octane fuel is all that is required. Higher octane fuels tend to build deposits in the combustion chambers that cause just what you do not want-detonation. Essentially, higher octane fuels turn an engine (that doesn't require it) into an octane junkie and, you can't hear an outboard "pinging".<br /><br />Outboards run relatively cool by other engine standards. Plus you have the combustion chamber cooling characteristics of the oil in the fuel.<br /><br />5. I've always had the best luck with Champions in OMC's. If DHadley says use them, then I would use them.
