Re: Need old Motorguide TM Wiring diagram
ok I have taken what I can off to see what is what. There are red, green, blue, and yellow wires going to the trolling motor from the pedal.<br />the green is connected directly to the ground. Others go to speed switch. My problem is it is a 12/24v trolling motor. with 3 pole/pos switch for voltage selection. center pole goes to breaker then speed switch. one pole is broken(obviously needs replaced) with a white wire going to power supply cable. other pole is a red wire also going to power supply. However some one has madesome connections on the other side of the power cable. It only has 2 wires coming out black and red( shows obvious splicing so colors may not be same ). Question is what is 12v what is 24v and will I hurt anything hooking it to 24v. TM runs alot fast when hooked to 24v instead of 12, but I don't want to fry it.
