Need new prop help!!!!
Dmaxx85
Ok so I have a 1990 glasstron sierra with a Volvo penta 230a andits time for a new prop and i dont eeven know where to start so if you guys could point me in the right direction and help me get the correct prop for my inboard/outboard i would appreciate it thanks
Re: Need new prop help!!!!
Ayuh,... I'll move this to the Prop forum, where you oughta read the "Read This First" thread...
1080tommy1
Can you get some more info from your setup??? RPM's WOT, speed, gear ratio so that a calculation can be made. Is there any other issues you want to correct, or is the boat running fine? How about the numbers off the existing prop. This will all make your selection more appropriate and if you are talking about purchasing a SS prop, you want to make the most educated decision because those props can be expensive. My 40hp was 281 dolllars and change. Good luck.
Dmaxx85
Yes I should have read the essentials part first! Anyway ..I will get the info needed as soon as possible! Thanks
1080tommy1
No problem, I did the same thing when I was starting to re-prop my boat. If you get that info, this site will get you on track for sure.
steelespike
If you look on the prop near the base of the blades or under the prop nut you may find numbers to help you out.
The performance info will help tell if the boat is setup well.
Dmaxx85
Ok so the main reason i want to replace the prop is because it had taken a beating this past year.
1)The boat runs excellent with 3 people but loaded with 5-6 people it falls on its face but honestly dont think it has anything to do with the current prop.
2)SPinelli bros, 9913,aluminum
3)14" pitch is 21
4)WOT most ive seen is 4000
5)Volvo Penta 230A/Volvo/120HP/
6)Glastron/1990/19.5'.
Im sure sure if that is the correct prop for this motor and outdrive because i know it was replace 3-4 years ago. SO it would be nice to know what the stock prop is also.
Thanks.
steelespike
Apparently you don't have the rpm and speed.
I believe the boat is 2000 dry weight I think the gear ratio is 2.15.
At 120 I think you would call it under powered. Your rpm is at least 800 short
of the rating.Assuming a healthy motor;A 17" prop should get you 4700-4800. Better hole shot and handle 5 or 6 better.
