Re: need new power tilt motor
If you have the two wire motor, you can get the motor and reservoir on e bay for around 250. Iboats probably sell them also, and a fellow called RRitt right here on this forum also probably has them. The three wire motor is a little more difficult to replace but you can replace it with a two wire motor if you are willing to do a little rewiring. ----not really a difficult job.
The two wire motor is better because it is a little larger and probably a little more powerful. It also is usually wired with a circuit breaker and relays, and uses only signal power at the trim switch, whereas the three wire motor used no circuit breaker or relays and the switch carries full motor power.
