Re: need more power from 3.8 V6's
No, they wont fit.<br />The 4 bbls will NOT get your boat on plane faster. They may even slow it down, as a matter of fact.<br /><br />4 barrel carbs are designed to allow extra fuel/air mixture in through the secondaries when the engine 'needs' it. The engine cannot take advantage of this extra air if it is running at a low rpm. Opening the secondaries at a low rpm as with mechanical secondaries will cause a 'bog' condition that will actually cause the engine to lose power. Once the engine speed increases, usually above 3200 rpm, then the engine will begin to take advantage of the extra fuel and air. This is why top end speeds tend to increase with the addition of 4bbl carbs, but low end pull and cruising speeds will usually stay the same. Most 4 bbl carbs are vacuum actuated secondaries, and those secondaries will not open until the thottle has been advanced to a certain point and engine vacuum is at a certain point. An engine at low rpm and a heavy load will not benefit from opening the secondaries at this point. An engine under a heavy load at high rpm will most certainly develop more power with the added fuel and air, so they will then open.<br />Yes, I know new (bigger) engines are expensive. But I speak the truth, even though it's probably not what you want to hear. <br />Your 270 is marginally powered to begin with, and adding 4 bbls to them will not make you any happier, only poorer. Twin 4.3's are marginal for that boat. That boat really needs twin 5.7's or 5.0's to get performance you would truly be happy with. <br />Find an owner that has done this and ask how happy they are. Thats about the only thing I can tell you.
