need mariner inline 125 piston help
quikstang347
ok here it goes took mariner inline 1997 motor apart and seized a ring to the piston.; the problem is i can not find the piston i need. the motor is
1997 mariner 4 cyl inline 125 hp
the motor has been rebuilt before and the bore is .030 over now . the piston that came out of it says
"582" on one side of the inside and "persan" on the other they are supposed to be pro pistons says the first engine builder
it is a flat top piston with 2 rings
the connecting rod # is 646-818846
i need thi spiston so i can assemble the engine . thanks for all and any help
Faztbullet
Re: need mariner inline 125 piston help
Call (800-621-7761) or go to Promarineusa.com and order a #6230 piston.
.030 Pro Piston
6230
Engine
.030 over size piston for Mercruy L3 & L4 inline loop charged engines 75hp thru 125hp from 1994 to 2005 with 3.500" standard bore size. Piston includes rings, circlips & wristpin.
Finished bore size of 3.530"
$116.99
