I am new to this forum, but I really need some help.
I have a 1986 Century Meridian 275 - We are relative novice's to boating. We have owned the boat for the past 3 years. Here is the situation....
We put it up last october for storage for the winter. Covered it, closed it up, winterized engines, drained water, etc.
When we went to uncover it last month, we discovered that somehow a LOT of water had come in through the hatch. The only reasonable explanation that I have come up with is
1) Someone broke into it through the hatch (Latch is broken) or
2) ice built up under the hatch and broke the latch allowing a lot of water intrusion.
And while we did not have a particularly snowy winter here in southern Michigan, we did have several periods of prolonged freezing temps, down into the single digits at times. When we went over it this summer there was excessive damage to the floor inside the cabin.. Looked like all the plywood just sort of separated. Maybe from freezing? and expanding? then maybe the excessive heat caused it to become more deteriorated more quickly? not sure.
SO.... We pulled up the subfloor to discover a copious amount of foam. I had expected to find the stringers (I've hear different things, and have been told the hull is a foam core hull, and that the stringers wouldn't be that far up, and are comprised of fiberglass therefore should not be affected...
Anyhow, not finding any evidence of wood rot, and only SATURATED foam, I was a bit relieved initially... UNTIL I thought about, what if that water froze in there? What kind of damage could it cause to the hull???
Also, I am wondering if 1) someone broke in or 2) ice broke the hatch latch ---- either of which broke the latch and caused water intrusion, would that likely be something I can claim on my boating insurance? Thanks in advance!
Misty
Misty
