Hi Folks,
I've got a 14' Aluminum fishing boat. It has a small livewell on the left side with a single drain/plug in the bottom which leads out throught the transom. Even with four people in the boat the well only fills a couple of inches when the plug is pulled. I'll need to make some changes to make this a functioning livewell.
I'm thinking about installing a pump (with a timer) to the existing drain line, to fill and circulate the well. I'll also need to install an overflow drain toward the top of the well (above waterline). My question is: If I do this, how will I drain the well when I'm done? The pump is only one direction right? It will fill the well but water can't go back through it to drain, can it?
Does anyone have any OTHER ideas?
