Need info on best GPS for Lake
pvanv
Re: Need info on best GPS for Lake
OK guys, time for me to chime in... As an electronics engineer, and a marine instrument installer, I can tell you this: All the civilian GPS units work the same, and collect exactly the same information. Position and Time. Period, end of sentence. Yes, there are WAAS and Differential systems to get closer accuracy, but we're talking feet of accuracy, not dozens of yards.
Based on that information (position and time), with decent cartography, you can get chart plotting. It's usually the charts that are lacking. I had a Magellan Color handheld that showed my truck driving through Lake Erie every time I drove to work, for example.
Since you already have paper charts of the area, my vote is for the cheapest unit that has a daylight-readable screen. BUT if you want chart plotting, make sure that your lake is covered by either the "base map" of the gps (at least), or by the chip that works with it. Then you will get buoys and stuff, updated to the last time the chip was updated.
FWIW, one of my units is an ancient Magellan Nav1200 that doesn't even have charts at all. Still as accurate as any, though, if all you want is a "you are here" lat/lon number for use with traditional paper charts. Likewise, my wife's Garmin nuvi 250w doesn't have any marine information in the database at all -- it's intended strictly for terrestrial use. However, the lat/lon position is still correct on the boat. Just no charts.
SO, the choice comes down to personal preference for the "language" of the machine, as well as the "look and feel" of the interface. Lowrance, Garmin, Magellan, Standard, etc, all have similar (but different) key strokes. This starts to be important if you are plotting routes and waypoints. So, yes, handhelds are fine, though you will probably want a 12v cord to extend the run time, and a unit that is reasonably splash-proof. But try a few out to see if you like how they "look and feel" before you buy.
sschefer
The question was best GPS for a Lake I believe. Civilian GPS systems must be capable of providing accuracy within 15 meters. In order to get closer you have to use WASS in combo with GPS and that usually means you need to be close to an Airport and able to receive radio frequencies.
The Lowrance 525c DF with an external GPS antenna can produce some very accurate data. It is a combo unit with multiple pages and can also be combined with Radar, (purchase separately). It has a 5" color display, great zoom features and multiple sonar display types. The best thing about the unit is that it works the best when you set it to factory defaults and run in the auto mode.
It also has a fish display mode but most folks learn how to read the arches which is much more accurate. Lowrance now has a broadband sounder unit that you can attach. It produces some amazing sonar definition. In addtion it is network capable and can be used with multiple displays and transducers. The best setup is one display up front on the fish deck and one at the helm. For transducers you mount one through the hull and one on the transom then switch back and forth when trolling or at speed. It comes with a built in map that is quite capable and you can also use the Fishing Hot Spots memory cards or the Navionics cards. A fully decked out system will run close to a $1000.00 (that's what mine cost after watching for discounts on the add-ons).
If you want to get into a less sophisticated system go with the Hummingbird. It's still a Lowrance but priced for the average Joe that just wants to enhance his fishing experience. It will do the job in most cases since on a lake, you rarely loose site of land and a compass, a decent watch and a little DR training is all you really need.
Just an FYI - I can shoot stars, have navigated with Omega, Loran C, Doppler Systems, GPS and am darned good at Dead Reckoning. So what do I need with a fancy over rated fish finder? That's easy, I don't want to work anymore, I want to fish and my Lowrance lets me do a lot more of it.
