need info on a 1979 starcraft tri-hull
hobster01
recently was given this boat and the capacity info plate is worn to where I acn't read it. How would one go about finding a new one, or getting the load capacity on this boat???/Thanks
barato2
Re: need info on a 1979 starcraft tri-hull
take measurements of critical dimensions on the boat (center length, gunwale length, transom height, transom width) and compare em with 79ish brochures. this should get you in the ballpark.
plan B, if floors are soft, is buy a tin hull and use trihull as engine/trailer/etc donor
