Need help
Coach L
2002 mercruiser 3.0. Motor tries to start. Getting no gas no fire. Last time used overheated and not sure what to do next. Any help is greatly appreciated.
Rick Stephens
Dump the water separator into a clear container, anything but clean perfect fuel will tell you what the problem is.
Coach L
Fuel was good. Not sure why it overheated and since cant get get gas or fire. Dont know what to check next. Can you give me a list of what to check off. Not sure of the next step or steps i need to go to in order to fix it. Thanks for the help.
Rick Stephens
So first is find why it gets no gas - this is same as a car - pull the line off the carb and stick it in a bottle. Crank the engine, anything come out? No - fuel pump or plugged line. Yes, the screen on the carb or the needle valve is crudded up.
Coach L
Ok. I will do that first thing tomorrow. Thanks. If you don’t care check back on this in case I need a next step. This is a huge help and thx again.
alldodge
overheated
When was the last time the impeller was changed?
With an overheat and if it was running before then do a compression test
Coach L
Checked the compression and it was bad in 3 cylinders. Guy told me motor was done. Now I’m trying to figure out how and where to find a new motor. Any suggestions.
alldodge
Several places to get reman's but what about having yours fixed? If it was just an overheat, most can be fixed with a head and valve job
Coach L
They guy that checked it said the motor was junked. I haven’t had much luck finding someone to do it. Didn’t know if it would be better to just get a another motor. I really appreciate the help.
cableguy1979
That doesnt explain why you arent getting gas or fire. Is it fuel injected? Computer controlled? Maybe a fuel pump cutoff switch. What was the compression? a simple head job could fix the compression issue so a leak down test is needed. Since it overheated it could be stuck rings...some marvel mystery oil helps alot unsticking these. You can put a brand new motor in it but if your not getting fuel or fire that engine wont run either.
