need help!!!!!!!!!!
fordmugg
i have a alpha one gen one outdrive on my boat i changed the u joints and yoke put all new seals torqued the bearings to a rolling torque of 5 inch lbs, i just re installed it and fired up the boat, now when i put it in drive at idle there is a speratic clunking in the upper gears but when i give it a little throttle it goes away..... now could the clunking be in gear and at suck a low idle there is no resistance so the gears kind of smack of should it not do it at all
Don S
Re: need help!!!!!!!!!!
Are you positive that is what you should have done with those bearings?
fordmugg
isnt it 3 to 5 inch pounds for re using bearings
Don S
Depends on your bearing setup. Do you have the small spacer with your bearings?
fordmugg
dont think i had the small spacer being i couldnt get the bearings off the gear. so whem i reasembled i slowly tightened the nut and keeped checking rolling torque till i hit 5 inch
ktbarrentine
Hmmm...doesnt sound like what I read in my manual.... What is your OD serial number?
fordmugg
ok guys i took the prop off yesterday and put it into gear without it and no clunking while in gear.. i have a backup aluminum prop that im gonna try today also.
achris
More fish than mountain goat
ser# 0A844620
Nope, not a valid serial number.. Like to try again?
The 'clunking' could be the dogs banging on each other if the idle speed is really slow and changing slightly. And the variation may not even be enough for you detect either. As long as when the engine speed is increased a little it goes away, nothing to worry about....
Chris.......
achris
And this is what I get when I put that number in....
attachment.php
I have also tried every combination of numbers that look like they might be something else. Like substituting 3, 9, 0, 8 and 6 for the 8, 6 and 0... Nothing comes up a drive.
Is the drive an original or maybe a re-manufactured unit?
Chris....
Don S
It's a reman, that's why you don't see it Chris, go HERE and try it.
achris
Sneeky... Thanks Don.... Would be nice if posters actually mentioned these things :D, but I guess that would take the fun out of life... :facepalm:
Don S
He probably didn't know it, and may have happened before he owned the boat.
fordmugg
Well I put the boat on the water yesterday and it seemed fine no wierd clunking or nothing, so I'm thinking out of the water I was getting gear slap cause there was no pressure on the prop
achris
It's not gear slap, it's the dog clutch.
fordmugg
Yeah your prob right .. I was just worried but now I feel better it was ok when on the water
