need help
pirate1313
i have a force 125 1989 or 88 i cant get it to spit water out the pee holes above the water at idle in mabove the propy driveway with muffs of submerged in a trashcan. is this normal if its a thru prop exhaust. water shoots out right above the prop. and a little bit of smoke comes out the pee holes on top which are labled POWER LOW. is the engine going to over heat if water is shooting out above the prop. IM REALLY CONFUSED. HELP
jerryjerry05
Re: need help
Your exhaust doesn't come out the prop.It comes thru the exhaust snout/trim tab above the prop.
If you aren't getting anything from the two holes above the cavitation plate on the back of the motor while on the muffs and your sure the impeller is good then your not getting enough water from the hose/muffs.Or the muffs aren't on right.It should be pumping while in the can.
Change your impeller if you have ANY doubt!!!!!!!!!!!!!!Jerry
